I have the same servo. Ended up using my Dremel to cut into the Rx box to make it fit. Sounds ghetto, but I used shower caulk to reseal the box where it meets the servo.Like I mentioned that is the 1/5 scale tray you see in the picture. Anyways. This servo is too big for even the 1/5 scale tray so modification is required.
Some cutting is needed on the tray and also on the cover . Came out very nice.
Anyone is interested in buying the hitec servo you need the 1/5 scale tray and it needs to be modded as well. So my suggestion is too look for another servo.
Get the PrimalRC Raminator servo. It's faster, stronger, cheaper and fits the 1/5 scale box perfectly.Which servo is if exactly? I am wondering about the servo model (irrespective your problem) as I am interested in alternatives.
It's very, very nice. Fast, and strong. But, it pulls enough power that you will likely need a glitch buster or even an external Bec. Mine was browning out on front tire landings until I added a glitch buster.I put my receiver in a thick balloon and zip tie the top so it is water proof.
How are you liking the servo? Better than stock?
