Hi,
Just thought I'd post an issue I encountered installing the Hot Racing AON4801 Steering Bellcrank / Servo Saver for my Kraton EXB build.
When testing the steering on the bench with the Hotracing Bellcranks installed, I noticed the steering was binding, slightly, at the extreme ends of the steering travel. On inspection I found that the Hot Racing bellcranks were slightly grazing against my Hot Racing front gearbox. To avoid this issue entirely by setting endpoints, I found I needed to set each side's endpoints to 65/100. So, a lot of steering travel sacrificed.
I then inspected the stock bellcranks, and found that Arrma has carved out a tiny notch exactly where the Hot Racing bellcranks were scraping. The stock Arrma parts almost look defective due to these notches which look like chips, however they need to be there to avoid binding. I considered dremelling out the hot racing bellcranks at that location, but concluded that it would be too dicey considering the proximity to the nut.
Long story short I went back to the stock bellcranks and the problem went away. I suppose that's the risk with aftermarket parts. But on the other hand the Hot Racing gearboxes completely resolved the issue I was having with varying mesh on the diff input/ring gears, where the mesh was very inconsistent when turning the input gear by hand. With the Hot Racing gearboxes the mesh was totally consistent through rotation.
Here are photos comparing the Hot Racing bellcrank with the stock bellcrank. Note the notch Arrma has removed out of the stock plastic bellcrank, and the small scratch where the Hot Racing bellcrank was rubbing up against the gearbox:
