ridgehead44
- Granite
Good Evening All,
The last time I ran my Granite V2, it ran like a dream. Then I had it on the bench for awhile making upgrades to the shocks, added a light kit, and a replacement ESC. The Hobbywing ESC wouldn't accept throttle after I'd unplugged all the electronics to add the light kit. It might have been a throttle trim issue all along, but that's another story/rookie mistake.
Anyway, I cannot get this rig to run right. I'm not sure if it's electrical or mechanical, or both. I run the EZ MAX10SCT combo and a Flysky gt3b. I thought I had everything plugged in correctly in the receiver--black wire to the - symbol. However I have to put Channel 1 in reverse to get the steering to work right.
So I have no idea what's going on with the throttle. I've swapped the wires on the ESC, but it doesn't seem to run right. It looks like I can get it to go full speed in reverse, but not forward. Even when I swap the wires, or change the programming card from CW to CCW and vice versa for the motor, I can't get it to drive right.
I wondered if maybe it was mechanical, so I tried my best to adjust the slipper clutch. I think I did it correctly, but maybe not??? In any case, I'm a bit lost at this point. I captured some footage of the vehicle. As you can see, when it's wheels are off the ground, the tires spin and balloon. But when I put it on the ground, it drives like an old Radio Shack rig. Not the 3S wheelie monster I'm used to.
Does it seem like the wiring and electrics are still swapped somehow and I'm not getting the proper torque from the motor? Or does this seem like it's more of a mechanical thing? Maybe both? I've posted the video below. I would really, really, really appreciate any help or advice. If more footage or info is needed to assess and fix this, please let me know. Thank you so much in advance!
PS, please don't judge me for my messy garage...
