Kraton1/8BLX V5 user
Hello,
I got the arrma kraton 1/8th BLX V5 about a week ago. I am having issues with its turning radius especially while the car is going quickly. I am trying to use the car as a dummy rabbit that my dogs chase so I need it to be able to turn better than it does right now so that I can out maneuver my dogs. I have already tightened the servo saver using 4 external circlip E- clip snap rings that were 14mm in diameter just like many youtubers did to improve the steering on the V4 Arrma Kraton. Putting these 4 rings helped my steering a lot but not enough as I can still not turn all too well. How should I improve my steering and turning radius? Should I tighten the servo saver by adding more external circlip E- clip snap rings? Should I replace the bushings in the servo saver for bearings? Should I upgrade my servo?
