Kraton JBIRC wheel nuts
James899
  1. Kraton 4s
Hey guys does anyone have any pictures of the JBIRC normal wheel nuts on a Kraton and have they held wheels on ok?
Cheers
I don't have them. But I can tell you that a decent set of wheel nuts will have a wider than normal flange that is deeply serrated. I use HR for Arrma wheel nuts. I have never lost w wheel to a lost wheel nut. I see many that have. But I check mine frequently. and they rarely if ever loosen. Even the stock ones were fine. The only reason I upgraded was for the closed cap design. It keeps crud out of the axel's set screw hex. And that set screw can be a bear to deal with when removing in general. So I try to keep it clean and free of corrosion by using a closed cap nut. It works.
Closed capped nuts are expensive considering what they are. JBIRC I don't believe is popular enough. So I doubt anyone has any real experience with them. They look nice however. But Bling is not my thing. Function and price point is how I roll.
