JDowns
I figured I'd document this build as it goes along. I couldn't resist another custom project after going into my LHS to order a 8S Kraton, so I walked out with a Limitless roller.
Going with another Castle Monster X / 2200 since I want to pull telemetry off of this build as well.
Custom ESC tray fitted into the existing ESC mount. Really like these threaded inserts from Penn Engineering. The existing (4) holes under the existing tray are used to mount the custom tray.
Added a mount for the power switch and had a left-over Savox for the servo.
Needed 12VDC for some accessories that will be added, so fitted a small 3S battery holder that gets clamped to the tower to tower brace.
Custom mount for a pair of Yeah Racing 30x30mm fans.
After some wear and tear I'll end up upgrading the bearing to Fast Eddy and at the same time the diff housing to Hot Racing. While all that is apart I have an extra set of Titanium turnbuckles from Lunsford Racing. But for the most part the internals of this will stay stock.
