dk10438
- Limitless
thanksIf you use shorter batteries you can use the standard receiver box with the XLX2. This is in Raz Shifrims Speed Run Secrets. The difference is he used gensacearespammers Basher Batteries and cut the trays, used dual lock on the bottom with a side straps. I'm sure this was the inspiration for Arrma doing the V2. You can probably just use the V2 battery trays and the receiver box as well.
I was watching that last night but you need shims on the bottom of the battery box cuz there's a bolt that sticks up at the back of the car that needs clearance. It's only like 158mm in total length. I think the 6200 CHNL's are 160mm and the 9500's are 172mm so a smaller receiver box would give it a little more space....
