Premium members don't see ads. Click here to upgrade.
Jerry-rigged answers the Siren's call...
Jerry-rigged
Have you seen my LVC?
ArrmaForum Fan
Texas, Baby!
, , 4x4-Mega
Howdy gang.
Been thinking for a while of maybe converting my Typhon to either an outcast or a siren. Last week I was digging through my spare parts bin, looking for parts for my son's kraton, and did an inventory of what all I would need to make one or the other projects happen. I figured it would take fifty to a hundred bucks to get either one of them done. After surfing eBay for a bit, I realized that for about two hundred bucks I could probably do both.😎
Parts order came in tonight, I'll probably start tearing down the Typhon tomorrow. Wish me luck!
bicketybam
Pathetic guy with a GoPro on his head
ArrmaForum Fan
New Milford, CT
Granite, , Talion, , Notorious, BigRock 4x4
What is a siren?
Jerry-rigged
ArrmaForum Fan
Texas, Baby!
, , 4x4-Mega
You're gonna need a lot of luck with all these parts man.
Lol.. no luck needed, except if I am missing some parts... 😎 (I say that now...)
But seriously, I've tore down my 2 6s cars enough, this should not be an issue. Just a bit of mix and match of parts...
Jerry-rigged
ArrmaForum Fan
Texas, Baby!
, , 4x4-Mega
Step one, strip the typhon chassis.
New chassis vs v1 -
This shows the "secret" @Thomas P discovered- use a second rear driveshaft up front, and shorten the chassis be 32mm (120mm front bone, 88mm rear = 32mm). Scribed, ready to cut-
bicketybam
ArrmaForum Fan
New Milford, CT
Lunch break. Just need to countersink, and the chassis is done. Not my cleanest work, but it should do.
Edit- derp, wrong pic.
So you have to drill all the chassis holes?
olds97_lss
Bash Break Repeat!
ArrmaForum Fan
Dekalb, IL
What motor/esc are you running in it? Guessing your going to run 6s?
Jerry-rigged
ArrmaForum Fan
Texas, Baby!
, , 4x4-Mega
Motor is a Racerstar 4069 2350kv. Esc is a Toro TS150. This is the same combo I ran in my Typhon for years. I'll start at 4s, but may try 6s.
Jerry-rigged
ArrmaForum Fan
Texas, Baby!
, , 4x4-Mega
A few other notes-
The body mounts are a mixture of parts from the senton 6's and the Talion 6s. I tried to run the Talion front shock Tower, but it didn't really work, it was too short. I ended up Drilling the Typhon shock Tower to take the Talion body mounts. In the back, the Talion body mounts bolted right up. For the body posts, all four are from the senton.
The ESC tray is the standard Electronics tray. I used the diff top brace that the senton and Kraton used to mount the roll cage, as a spacer. The electronics tray, I just drilled to match the hole pattern, countersunk it, and used some really long screws. works great, and you still have the wire holder to keep things tidy.
For the chassis braces, the front one just doesn't fit. I'm going to need to Fab something up for it. For the rear, for now I don't want to run the wing. Without the wing, the rear brace has nowhere to land. I think I have an extra Wing mount in my parts box, so I will probably just cut one up so that I can use the rear chassis brace. With no chassis braces, there is a lot of flex, I really don't want to run it like this.
One last thing I think I'll still need to do, is the wide mod. I have all the parts for it, just did not get it done before I ran out of time today.
olds97_lss
Bash Break Repeat!
ArrmaForum Fan
Dekalb, IL
I made a front brace like that after I broke mine. Made it out of 1/4" square steel stock. Was a pain getting the bends right... then Christmas came and my wife got me the hot racing ones, so I never actually used it.
Jerry-rigged
ArrmaForum Fan
Texas, Baby!
, , 4x4-Mega
I hear you on that angle. I had to test fit, it take it apart, file just a bit, repeat, several times to get it right.
Jerry-rigged
ArrmaForum Fan
Texas, Baby!
, , 4x4-Mega
Got my first run of the Siren in. Ran it with buggy lockups for now. This run was just in a kids park, no real jumps. Had a guy come over to chat, so I handed the remote to my son, and he promptly ran it into a telephone pole... lol, Grrr...
First broken Arm, first broke plastic part EVER for my Typhon in the two + years I have owned it.
Lucky, I have the spares, so it was fixed in about 5 minutes after getting home.
Jerry-rigged
ArrmaForum Fan
Texas, Baby!
, , 4x4-Mega
Pretty day for a lunch bash. Got about 5 minutes of running, and a motor lead de-soldered...:facepalm🤯
May post the running vid a bit later...
Jerry-rigged Arrma 4x4 265
Similar threads
