Jims Bearings Waterproof Grease for Spiral/Spur Gears?
JustAnOutcast
compulsive over-thinker, I think. 🤔
Anybody using this grease for your diff external gears? I was attracted to the fact that it contains lithium and molybdenum. And supposedly “protects after the grease is gone”.
Thoughts and comments appreciated. Thanks!
SrC
RC is a lifestyle choice
Hospitality Award
Queens, NYC
  1. Fireteam
  2. Infraction
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Outcast 6s
  8. Typhon TLR
Yeah anything with a Moly is long wearing. (y)
I find that most any Automotive Grease has the correct lube properties for these diff main gears. I choose Synthetics. Mobil 1 Red, Superlube, and Lucus Marine grease (high lithium based and water proof). More than adequate.
RC boutique lubes are just repackaged Commercial greases.
You get more quantity with automotive grease for the $$ spent.
jkflow
TB RC Bashers
Hospitality Award
Tampa, FL 🇺🇸
  1. Infraction
  3. Talion
Any grease will work, doesn't need to be fancy or waterproof. You have to do maintenance before grease is an issue or even close to being a problem.
Doesn't have to be waterproof either, if you drive in water you do more maintenance anyway.
Yes, it will work just fine, pot o'grease from dollar store will do exactly the same for your RC.
RCbuzz
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave EXB
  5. Senton 3s
Hmmm usually lithium is a no-no on plastics.
I use Superlube Synthetic or Superlube Silicone grease for the diff gears. Perhaps on the 6S line it doesn't matter as much? I am not sure what the plastics are made of (diff cup and housing).
You can search the forum on what lithium grease did to several members here on the forum on their 3S rigs. It softens the plastic over time...
https://bisleyinternational.com/difference-between-white-lithium-grease-silicone-grease/
SrC
Hospitality Award
Queens, NYC
  1. Fireteam
  2. Infraction
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Outcast 6s
  8. Typhon TLR
Silicone grease is not as durable for the 6s Main/Input metal gears. It will thin out easily. It isn't Tenacious enough on the gear's teeth.
Yeah Lithium is better for metals, not plastic. Pure white Lithium grease in general I don't find lasts long. It cakes/chunks up. So more wear would result IMHO.
Any Automotive grease you would use in Auto wheel bearings or Ball joints is way more than adequate protection between rebuilds.
And I would use a Non-Moly synthetic grease for plastic diff gears. I feel Moly is best for Metal on Metal gears and can wear out Plastic gears faster.
Molybdenum is actually a super fine metal. Reacts and benefits with metal better, not with plastic because it is slightly porus. (composite plastic gears)
Velodromed
One to turn, two to burn.
San Antonio, TX
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Kraton 4s
  5. Notorious
  6. Outcast 4s
  7. Vorteks
  8. Voltage
  9. Infraction 4x4
Edit: *my bad, I thought you were talking about a 4s outcast. SRC knows best here, listen to him not me. The below is for a 3/4s arrma.
The grease in the diff housing will get contaminated with dust fairly fast anyways so don’t bother with boutique grease. Get a $14 tube of superlube and a $12 small grease gun. Clean and re-lube monthly because it’ll probably need it.
Astro Pneumatic Tool 101 Mini Grease Gun https://a.co/d/3APZKXK
Super Lube 41150 Synthetic Multi-Purpose Grease, 400g, Translucent White Color https://a.co/d/02SOhsy
SrC
Hospitality Award
Queens, NYC
  1. Fireteam
  2. Infraction
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Outcast 6s
  8. Typhon TLR
+1
Exactly the same pump I use. Off AMZ.
Pumping this way keeps the lube cleanly dispensed. And there is less waste. Easy to fill my BB's too. Great lube for BB's. A high temp grease.
I buy that same SuperLube, just in a Tub can from HD. I use a spoon or knife to fill the pump. I refill the pump like maybe once a year. This SL is great stuff. Around water also. Stays put when wet.
SrC
Hospitality Award
Queens, NYC
  1. Fireteam
  2. Infraction
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Outcast 6s
  8. Typhon TLR
I never felt Molybdenum was great anywhere near plastic gears. Moly is a fine metal. Makes sense to me.
I could be wrong???:unsure:
I don't own any 4x4's.
All metal geared 6s rigs.
FWIW, I once tried a Ceramic Lithium based Bendix Brake grease on my metal diff gears. It caked up after little use. NG.(n) I like to experiment.
Velodromed
San Antonio, TX
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Kraton 4s
  5. Notorious
  6. Outcast 4s
  7. Vorteks
  8. Voltage
  9. Infraction 4x4
+1
Yup you told me bout it and we’re right, it’s a great little pump 😊
Glad you caught this. Double checked and website says synthetic with Moly additives. So no lithium. 😰
Red and tacky is lithium based by the way.
SrC
Hospitality Award
Queens, NYC
  1. Fireteam
  2. Infraction
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Outcast 6s
  8. Typhon TLR
Yeah R & T is not a fav personally. I have it here also. Not for RC. I tried it. Many like though. :unsure:
I use it on other things around the house and my SUV.
JustAnOutcast
Good to know. My OC 6s has metal gears.
Thanks for the links! I added them to my Hobby Wish List. Dang, I hate Amazon Prime, I could have this stuff tomorrow! :ROFLMAO: Nah, I’m gonna use up the boutique stuff first…. With Arrma recommending diff service every 10 packs on the newer 29mm LSD diffs, that won’t be too long! Thanks again!
RCbuzz
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave EXB
  5. Senton 3s
Oddly enough I have not had issues with Red and Tacky softening plastic...
JustAnOutcast
The only info I can find about any substance damaging plastic is if it contains some form of petroleum. Couldn’t find anything about R&T saying it contained petroleum. 🤷‍♂️
