Typhon Jos Typhon
Jos
Hello,
Here is the first evolution of my Typhon: esc Hobbywing quicrun 150A.
It was also a first for me: to solder :oops:
it works :)
Tomorrow, fixing esc, it is possible to fix with 4 screws,
the template :
and cleaning car :oops::)
Thank you Thejoker :)
I will, as soon as the ESC is fixed. I am impatient. Typhoon VS T....y ...
Thanks !
it's impressive how it's tensile strength.
I watched several videos on youtube before, I did not forget to thank :)
ESC must be in abutment on the small flange of the bracket, well place the template, drilling the 3 holes in the bracket.
The Quicrun is one of the best ESC, well done!
But the Dean plugs are bad plugs with too much electric problem because of the limit 40-50A delivery... With Dean plugs, you can have battery and ESC issues, be careful with!
Better to use something stronger 90a-120A like the XT90 XT150 or EC5 plugs.
I use the XT90 and never had esc or battery electric problem with 6S full power delivery.
My Typhon with stronger XT90 plugs.
hello Arrmada,
I saw your XT90.
I used dean plugs because i still have a small stock. Until then, i had no problem but i note your recommendation, thanks ! :)
it will be for the next evolution ;)
[DOUBLEPOST=1463160515][/DOUBLEPOST]about quicrun, what happiness !
2 hours run without any problems last weekend :cool: the engine is not warmer. I'll finally be able to work on the chassis !
thanks for advice ;)
