- BigRock 4x4
- Kraton 8S
- Kraton 4s
- Nero
- Outcast 6s
- Outcast 4s
- Typhon 3s
Was waiting to create a build thread until the rig had been run. Well, I did that yesterday so it's officially done and in need of its first repairs...
Since Arrma discontinued their 4s line I was forced to come up with my own version of their Outcast 4s.
My inspiration was from a couple of sources; @Steve38 who pointed me towards the roll hoop I was hoping to install on my Bigrock, and the second came in the form of a sweet deal on a local sale for a complete Typhon 3s which also had a brand new spektrum 130a esc and 2400kv motor still in the box, a set of hoons, and a full castellated 4s slipper. Basically close to 300 in new components that made it more attractive to build out this rig.
I will say this because if your reading this I know you're thinking it. This is probably the most expensive way to build a car, and I would have been better off building a Kraton 4s using the Typhon chassis I just bought above. If it weren't for the smoking deal on the electronics and slipper, I would not have moved forward with this and will most likely not do this again unless it's a roller. At this time I probably have well north of 400 into this build and I just ordered Arrma upgraded CVDs and HR yokes $$$... In comparison, I just acquired a K4S that was intact and operational. I spent about 20.00 for parts to repair it and another 40.00 to upgrade the rear diff to steel gears. Total investment of 340.00 and it has a TBR exo cage and RC4GS Tx/rec combo.
Driving the two rigs is like night and day. The OC although the wild child of the two is significantly more precise and smooth.
I started acquiring the parts around Dec 16 for this build. I finally completed the rig early in January, gave it a quick electronics check, then disassembled it to upgrade and fill the diffs and top off the shocks. I installed Arrmas CNC cut crown and input gears, and a composite diff cup at the rear diff only. Will see if that plan works out...
With help from some fine folks here @HZRDOS and others, I was able to address the weak areas in this build and upgrade as it went along. I was hoping I wouldn't need the upgraded Arrma CVDs but it appears I was wrong....
Most parts were sourced on Ebay and Amazon ( free shipping). The chassis, DX3 Transmitter and SR6200A receiver, and core chassis parts are from Jenny's RC.
Any odd parts I overlooked I sourced through my LHS.
Upgrades:
-RPM arms ( technically the only available choice anyway)
-M2C racing motor mount and brace
-GPM front upper body mount bracket
-Hot Racing pivot balls, C-hubs steering servo and yokes ( ordered)
-Integy shock tower braces ( waiting on rear)
-Arrma Typhon 6s v4 shocks
-Arrmaskinz chassis skin
-Spektrum 130a esc and 3668 2400kv motor
-TBR front bumper
-Spektrum Dx3 transmitter and 6200A AVC receiver
-Arrma upgrade CVDs w/ 17mm hub adapters
Upgrades:
-TBR front bumper
