Vorteks Junk on screws and motor mount
vortekyteky
New Zealand
  1. Vorteks
Hi, this is a brand new vorteks.
Ive just removed my motor from my vorteks and noticed a clear greasy coating on the red motor plate and the motor itself. I also opened the end of the motor and it looked a bit greasy in there. Is this normal?
While doing all this I also noticed most of the screws had either a white, brown, black or dirty looking substance on the screws. The screws with this were the ones holding the motor to the plate, holding the plastic cover over the spur and pinion gear and the ones at the end of the motor that keeps the black plastic cap on. Do I need to worry about this?
I have tried cleaning it up a bit and got all the grease off but some of the stuff on the screws won't come off. It doesn't affect how they screw in.
Thanks in advance.
North Liberty, IA
  1. Infraction
  3. Typhon 3s
  4. Typhon 6s
Thanks in advance.
View attachment 273830 View attachment 273831 View attachment 273832
Looks like thread locker to me, should be normal. Also, if you're reinstalling those bolts into the motor, diff case etc I think you should clean all of that old residue off w/ alcohol, brake cleaner etc. Will bond better if you can also clean the mating surface/female part they're going into
vortekyteky
New Zealand
  1. Vorteks
ok thanks, what do you think about the greasy stuff on the motor and motor plate?
Thread lock, at least it's not red Loctite.
haha wouldn't be good
Velodromed
One to turn, two to burn.
San Antonio, TX
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Kraton 4s
  5. Notorious
  6. Outcast 4s
  7. Vorteks
  8. Voltage
  9. Infraction 4x4
But it’s the plastic spur case those screws go into. I’ve never seen it there like that on a 3s car. There are very few spots for loctite on them. It looks strange.
Thanks in advance.
Post a pic of the motor if you could…
ZooKeeper
Quack!
Chicagoland Burbs
  2. Granite Mega
  3. Infraction
  4. Kraton 8S
  5. Senton 3s
  6. Typhon 6s
The screws actually go through the plastic case and thread into the aluminum motor mount plate - thread locker should be used here.
slick2500
Community Leader
Rapid City, SD
  1. Fireteam
  2. Kraton EXB
  3. Outcast 6s
  4. Senton 3s
  5. Typhon 3s
Those screws go into the metal motor plate through the plastic, they don't screw into the plastic at all. If you buy a new motor module from Arrma and use brand new screws they go right through it. That is why they need thread lock on them.
Sorry I didn't even see your post until after I hit post reply.
Velodromed
San Antonio, TX
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Kraton 4s
  5. Notorious
  6. Outcast 4s
  7. Vorteks
  8. Voltage
  9. Infraction 4x4
Good grief, with all the 3s cars I have I can’t believe I forgot that. I even had to look again because my mind was not wrapping around It. I never use Loctite on those screws. Have not found a need for it because they stay tight between cleanings. Thanks man.
ZooKeeper
Quack!
Chicagoland Burbs
  2. Granite Mega
  3. Infraction
  4. Kraton 8S
  5. Senton 3s
  6. Typhon 6s
I can't lie, I went and looked at one of my 3s rigs to double check as I was questioning my sanity. :ROFLMAO:
vortekyteky
New Zealand
  1. Vorteks
Hi everyone, thank for all the replies, any thoughts on what the oil in the motor and on the motor plate could be? It looked a bit like silicone oil.
The motor has never been run once. Sorry I can't get any photos.
slick2500
Community Leader
Rapid City, SD
  1. Fireteam
  2. Kraton EXB
  3. Outcast 6s
  4. Senton 3s
  5. Typhon 3s
I know they use some sort of oil/lube during assembly of the car, everything on my Fireteam had a light coating of whatever it is on it as well.
