Infraction Just another "Mega" project
Well shoot guys.. not really what I was expecting once again!! 😡
It did heat up, took my gun this time.. mid 150's, highest i seen was 158 at the motor, esc ran relatively cool.. low 130's!! I was running the dog tar out of her.. kept hitting LVC, both lipos!! 😞
I think I have officially maxed out the 100a esc 3200kv combo without destruction!! It held up good and took it in stride, therz was def no holding back!! Shes quick, and pretty feisty but no cigar!! I guess next up on the list is 130a with idk what motor yet!! Bash on bros!! 💯
On a good note.. I did break the 2 second club at 132'!! 🎉
That darn LVC!!! :mad: 😂
Can't wait to see what cha got next!!! (y):LOL::cool:⛄
I just now noticed, I was doing some drag pulls right before I ended the sess.. look you can see where I hit it on the graph!! 🤣
And by the way I was wrong, both lipos were dead, so maybe it was holding up!!
Ok got another session in today, trimmed up the wing a tad more and "squared" it up one more time.. I actually like these tires once u knock the knobbies off and get them adjusted right, they actually hoon around pretty well!! Stuck at 66.. def ran both lipos dead yesterday.. no LVC today until the end of the lipo!! 🙌
I imagine the 50/32 is just smoking the lipos way faster now.. used to getting 25+ mins out of them and now I'm down to around 18 or so.. bashed around as well and still getting the same mid 150° to 157 or so temps.. kinda high but should be ok!!
So my next move here I guess would be to swap the motor and esc.. I'm almost positive she is at her limit!! Will try again though with some bigger tires and see how much of a gain it is with temps/speed, not looking like she can handle much more unless I simply do 1 or 2 passes and take a break.. but who tf wants to do that!! 🤣
Oh yea, I rolled it twice into the grass, and they weren't half hearted rolls either, these were full fledged, full speed dumps into barrel rolls!! 😳 Took it like a champ and landed right side up, right back into the rd both times! 💯
Well idk how but I pushed 1 more mph out of her, she took the smack down pretty decent, I'm thinking i can push it more!! 🤣
Manageable temps, this was after 3 battery packs and I rested after the 2nd.. higher temp was the motor of coarse!!
I'm gonna order the spool and pick out a spur, what do you guys think would be a good starting point after the 50t.. i think I can go down significantly if I just do a hit or 2 and take a break!! Let me know!! 💯
Thoses temps are right where I look at resting mine. Maybe a bit higher. And you’re just 6 miles short of where I bowed out with mine 😊
Yea I'm gonna keep pushing it, seems to be holding up good, just wanna see how far I can go with the stock little blx100.. it seems to be taking it better than the motor is atm!! 🤣
Good speed with blx100..Best addvice i can give with setup is not really much until ya upgrade esc...castle is the way to go with speed..ya they are expensive, but castle takes car of ya after ya burn um up...like 80-90$ for a non warranty replacement on mm2 an mmx6s..like 130 on mmmx8s.so after ya break um it's not a total loss..I'd advise running 20mil in diffs,car gos straighter an no more 1-wheel-peal going on..turn off lvc,punch on 1,timing turned down..motor temp tells ya when motor is at its full potential...2 yrs ago I ran 78mph with blx185 an cheap surpass 4068-2650kv on 6s with 26/50,senton kept going airborne, with new spool this motor would do great I think...could went past 80 easly ...MM2 AN 4068-2650KV WOULD BE A GREAT COMBO
This is the one that got me into speedrunning
What do you have mounted on your front risers?
Nope, with the hurricane and the tree falling on the house i have been swamped, just had an exam last night, so I'm stuffed and still have a whole plate!! 🤣
Damn bro... Didn't know you were in the path and definitely didn't know you had a tree fall on your house! Hope everyone is OK and you get the house squared away pronto!
Dude, this is crazy! Best of luck to you guys!
