Check all the screws and make sure it wasn’t built on a Friday. If it has an STX2 radio, replace it ASAP.So, I snagged a Talion for dirt cheap as my first entry into arrma. I’ve ordered a servo mount, new servo from Dave, front bumper, and wheelie bar.
Anything else I should do to this thing before I put it in the dirt?
Also... Be prepared to buy diff oils, some good quality hex bits, a decent soldering iron, vent your tyres properly.. and do a forum search before attempting to fit any new parts or maintain it.... because Arrma use some pretty hardcore loctite on certain items and we don't want you to strip your hex bolts etc like we did..
Hotter the betterI’m sure I’ll have lots of dumb questions.
As far as venting tires goes, I don’t have any small tubing, but I’ve got plenty of drill bits. My question is, if I heat the bit on a stove burner, will that be too hot to drill the rubber, maybe boiling water, cigarette lighter? How hot does the bit need to be or is there really a too hot?
A soldering iron with a fine tip would be ideal but if you don't have one I'd try using a gas cooker flame on a 2-3mm drill bit.
You could try a lighter, just not sure it would get hot enough unless it was a jet flame lighter though..
