No it just sounds normal... but as soon put on the arm it tightens back upIf you remove the horn from the servo does the servo still bind and whine?
The 1st was yeah spektrum the second eco powerWhat servo are you using?
If it's a Spektrum one and these are all replacement of the same model, that is your problem.
The stock Spektrum is known to be bad.
Check your entire steering system for anything binding. Double check your servo saver.
ya, make sure there is nothing jammed in there or blocking it. and there is minimal friction.With servo unplugged?
