StephenSchandelmayer
Rig of the Month Winner
Always wanted one and finally decided to get it. Any tips and or advice is more than welcome!
I really haven't learned the language of it all yet so I have some studying to do and then I can refer back to what you guys are saying here. I appreciate the input.You might want to calibrate the esteps to prevent any extrusion issues, I had to do it on my ender 3 pro in order to get a good print. If you have never used a 3d printer before, learn how to level the bed as that’s one of the biggest causes of bad prints. I would also invest in a heated box for the filament, it really helps with keeping the filament dry.
Sounds weird that you need to keep it dry but sounds like it makes a difference because I saw that somewhere else as wellYup. Learn to level, keep your filament dry, and play with Cura, or whatever slicer you use.
And have fun!
So true! I managed to find the correct settings for both Hatchbox PLA and Overture PLA Plus, but it took a lot of tweaking and tuning to make it perfect.Oh and another quick note-
Don't assume whatever "good" settings you used for one filament brand/type/color on a successful print.., that you can just used that "same settings" for All future prints no matter if you just switch color etc.
Filaments are ALL different, even just different colors of filament from the Same manufacturer can have different requirements which can lead to random bad prints. So, be prepared to make setting adjustments for each type/color of filaments and keep good notes on those settings for the different filaments.
Yeah, PLA plastic can absorb water out of the air, and when it gets wet, it get brittle and won't print right. If it is very wet, it will pop like tiny popcorn while printing, as the water boils out of the plastic. I have a pair of these renewable de-humidifiers in a sealed/gasketed waterproof tote bins. Stick a Hydrometer to the lid and you can keep track of when you need to renew the dehumidifiers. Cheap-ish setup, but works. I also have a second set-up, for my son's welding rods. Weird the things that will soak up water out of the air...I really haven't learned the language of it all yet so I have some studying to do and then I can refer back to what you guys are saying here. I appreciate the input.
Might just copy you on that then! Thank you for the list of things I appreciate that a lot. Do you keep both the de-humidifiers in at the same time or do you cycle them as you need to charge them?Yeah, PLA plastic can absorb water out of the air, and when it gets wet, it get brittle and won't print right. If it is very wet, it will pop like tiny popcorn while printing, as the water boils out of the plastic. I have a pair of these renewable de-humidifiers in a sealed/gasketed waterproof tote bins. Stick a Hydrometer to the lid and you can keep track of when you need to renew the dehumidifiers. Cheap-ish setup, but works. I also have a second set-up, for my son's welding rods. Weird the things that will soak up water out of the air...
My thought process at the moment is printing rc parts. Fan mounts and such, is there a material type you would recommend? Thank you for all the info i very much appreciate it, I did see somewhere else to lower the speed as well so I made note of that.1. Getting your bed level and maintaining it ,is crucial. Just comes with practice.
2. Now getting that FIRST Layer printing correctly And Consistently will be a challenge for new users. So, be patient and keep an eye on how the filament is being laid out on the print bed. You'll eventually get a feel and see how it should be on "good prints" and when it starts to deviate - which usually means something is getting out of alignment or some other print issues coming...
3. Try to hold back on the temptation of pushing your Ender to print at or near its Maximum speed. Slow and steady is the key to consistent reliable prints verses Failed "noodle" printing, delaminations between layers of printed parts, or your prints being knocked off the printbed half way thru a printing process...
Just keep in mind, whatever is listed as its capable print speed is usually just the theoretical speed , usually just marketing bullet points to sell you the printer. It's not the ideal nominal speed. So keep it slow, you're get much better results, waste less filaments, and be happier with 3D printing.
Good luck and Happy printing!
I actually have 3. Two are older and saturate at a lower humidity vs the newer one. So they change color first, and I will pull them for regen, and leave the other in the box. When the first ones are done, I will swap them and regen the last one.Might just copy you on that then! Thank you for the list of things I appreciate that a lot. Do you keep both the de-humidifiers in at the same time or do you cycle them as you need to charge them?
