Im going to need a name.
Sort of want a
"lowered nose, ass up" street car along with some light lawn-grass with buggy tires, type of look and feel.
I'll likely run a 50t with a 22 pinion (+/- 2)
Thats around 75-85+ mph potential on 6S. And with 3S its in the 40's for the younger drivers.
- Typhon 6S body shell.
- Kraton 6S V5 BLX Wing (I also have a Typhon Wing)
- dBoots Exabyte Tires (118mm X 42mm)
- dBoots Hoon 100's and 107's
- Firma 150 ESC (stock 6S)
- Firma 4074 2050kv motor with Yedi twin fan cooling and HS.
- Arrma 6S V5 BLX Red Sliding Motor and Dif Mount
- Typhon 6S V5 BLX - center differential (50t spur)
- Typhon TLR Diferencial's, F/R (3.3 ratio)
- Flysky FS BS6 Gyro Receiver
In the front:
- TLR arm pins with steering rack.
- Typhon a-arms & hubs.
- Limitless v2 6S - front shock tower
- Infraction 6S - rear shocks
Shock body 16 x
36 mm
Shock shaft 4 x
43 mm
Springs:
40 mm 4.7n/mm (27lbf/in)
In the back:
* either;
- Limitless v2 6S - rear shock tower
- Typhon Rear Shot Tower
- Lowered Mojave 6s EXB rear shocks
Shock body 16 x
61 mm
Shock shaft 4 x
73.5 mm
Spring: using a
95 mm 0.87n/mm (
5.0lb/in) (original was
110 mm 0.56n/mm (
3.2lbf/in)
Trying to use what I have but may want Mojave Front shocks in the rear instead!
Have to see how they look with either tower.
Mojave front shocks stock
Shock body 16 x
51 mm
Shock shaft 4 x
59.5 mm
Springs:
70 mm 1.35n/mm (
7.7lbf/in)
