Kraton k6exb 'beefcake'
BUILD UPDATE: P3 COMPLETE!!
Key updates include:
_alu bulkheads
_alu bell crank
_alu hubs
_alu diff cases & rebuild
_revised cooling system
_overall refresh of plastic bits (including cosmetic)
Significant weight reduction measures were taken to balance addition of alu parts, successfully (and surprisingly) reducing full weight from P1 build of 15.4lbs to current P3 build of 15.2lbs.
Looking forward to 'pressure testing' this build after the threadlocker cures tomorrow 😏 will update after shakedown with GPS speed on new backflip LP / 22t pinon setup.
Parts List (current):
CategoryBrandDescriptionPart No.
Chassism2cCHASSIS3000
Chassism2cREAR SHOCK TOWER3400
Chassism2cFRONT SHOCK TOWER3401
Chassism2cFRONT CENTER BRACE (POLISHED)3047
Chassism2cREAR CENTER BRACE3046
ChassisVitavonCNC Front/Rear bulkheadNA
ChassisPPSGrublock Motor MountNA
Chassism2cFRONT HINGE PIN RETAINER KIT w/ BUMPER MOUNT3616
Chassism2cREAR HINGE PIN RETAINER KIT3615
Chassism2cREAR SHOCK TOWER BRACE3035
ChassisBasherqueenCarbon Fiber Top Plate - 5mmBQNA320195UHD
ChassisBasherqueenCarbon Fiber Rear Mudguards - 2mmBQNAMDWV5
ChassisJust Bash ItServo Mount Extended HeightNA
ChassisAvid RCCeramic Revolution BearingsAV-ARR-TAL
ChassisPPSESC Switch MountNA
ChassisArrmaMajove Rear Bumper (cut down)ARA320540
ChassisBasherqueenGearbox / Bulkhead GasketsBQNA310854
ChassisRC ScrewzStainless Steel ScrewsRCZARA007
ChassisXunweiAlu Rear Center Brace MountNA
CoolingGame ChangerTyphon v2 Fan (For ESC)NA
CoolingGame ChangerGCVR HARDWIRE with on/off switchNA
CoolingGame ChangerTyphon v2 2x Fan (For Motor)NA
CoolingAlza Racing40mm Aluminum Fan Cover (for ESC)NA
CoolingAlza RacingDual 40mm Aluminum Fan Cover (for Motor)NA
CoolingAlza RacingMotor 40mm Fan Mounting base (for Motor)NA
DifferentialsTekno22T PinionTKR4182
DifferentialsVitavon29mm V2 Diff Case Alu+HD SteelNA
Differentialsm2cDIFFERENTIAL OUT DRIVES3402
DifferentialsTLRSilicon Diff Oil (50k, 200k, 20k (F/C/R))TLR5286, TLR5284, TLR75008
DifferentialsTekno13x16x.1mm, Diff ShimsTKR1222
DifferentialsTekjoDiff GasketsNA
DifferentialsLucas OilRed n Tacky Diff Grease10318
DifferentialsKyosho8x12x0.2mm Shim (for main input gear)KYO96773
Drivetrainm2cDOGBONE REAR CENTER DRIVESHAFT310460
Drivetrainm2c17MM +5MM HEX UNIVERSAL HEX ADAPTER FOR 8MM AXLES3500 Rev B
ElectronicsCastleMAMBA MONSTER X 8S, 33.6V ESC010-0165-00
ElectronicsCastle1717-1650KV Motor060-0081-00
Electronicsgensacearespammers22.2V 6800mAh 6S 120C LiPo Battery: EC5GEA68006S12E5
ElectronicsPowerhobby760MG Brushless Digital Servo (Running @ 7.4v / Stall Torque: 49kg - 680 oz-in)PH760MG
ElectronicsFlySkyNoble NB4 TransmitterNB4
ElectronicsCastleESC Bluetooth Adapter011-0135-00
ElectronicsCastleMotor Sensor wire 250mm011-0150-00
ElectronicsFlySkyFGr4 V2 ReceiverFGr4 V2
RollerArrmaDONOR CAR - Kraton 6s EXB Roller 1/8ARA106053
Shocksm2c16 MM ZRS SHOCK CAPS AND ORING SHOCK PISTONS3480
Shocksm2cSHOCK TOWER STAND OFF KIT3080
Shocksm2cSHOCK CAP BUSHING3076
ShocksArrmaMachined shock seal guide setARA330729
ShocksArrmaX-Ring Shock SealsARA711003
ShocksTLRSilicone Shock Oil 80wt / 1000cstTLR74016
SteeringVitavonFront & Rear HubsNA
SteeringVitavonCNC 7075# Servo Steering Bell CrankNA
SteeringBasherqueenCarbon Fiber UHD Steering Plate A - 5mmBQNA340072UHD
TiresdBootsBackflip LPARAC9468
View attachment 230109View attachment 230110View attachment 230111View attachment 230112View attachment 230114View attachment 230113View attachment 230115
What are you powering your fans off of?
12v BEC soldered to ESC leads. Runs to a y-splitter (one to motor fans and one to ESC fan).
Build update: Added Qs8 connectors and re-wired my cooling in hopes of resolving hot battery issue. Not sure why else my battery would be getting so hot when my motor / esc are ending full-out :30 run ~130’s in 100deg ambient. Even had a relatively new gensacearespammers puff up on me so hoping this resolves it. Also replaced a couple blown hub bearings. Cannot believe how quick they went out but perhaps due to how dry and dusty it is. Expect to be able to rehab some of them, but at least 2 of 8 are gonners. Trying fast eddy ceramic rubber sealed this time.
View attachment 232020View attachment 232017View attachment 232018View attachment 232019
Not sure which one to drool 🤤 about, the Kraton or how organized your tools are 😍.
Thank you.. workshop was my pet project during early days of covid so doubt I’ll get to ‘gold plate’ anything as much until retirement. The crown jewel of that exercise was def my go-tool kit tho; it’s all I used/needed on P1 of this build:
Car’s been a riot to drive and has been running great, but I know it has more to give with avg motor temp ~135deg at lvc. Rather than gear up (currently 22/50) I decided to test it on 8s..
A bit of soldering to go to build a series harness and replace the CNHLs’ EC5s, as well as replace a bent rear drive shaft, and double check bearings and I should be ready to rock (and very likely roll :rolleyes: )
Will lower punch setting for this experiment, but any other tuning tips for running a 15lb 1/8 scale on 8s would be greatly appreciated!
Note: Not a long term change, just curious.
So apparently the the “aluminum” front center brace mount I got from eBay is actually made from a high tech lead alloy, including the screws! :rolleyes: This little screw breaking resulted in ~2h of work to get the truck back to where I started, and the new mount in the trash.
8s update: it was awesome zero regrets. Didn’t even get close to full throttle the entire time and I’m more than ok with that. Perf backflips going ??mph (fast) just by blipping the throttle. The speed where 6s begins to drop hard acceleration felt like 8s was just getting going. Terrifying on greasy copperheads, will throw on a new set backflips and take it out to the dirt for a real pressure test this weekend.
& those bricks didn't get jostled around in there too badly? Looks like you could use another battery strap?😬
Lol so far so good after a few rolls but didn’t come close to sending it so only time will tell. Also worth noting I removed the closed cell bumper pad I normally keep under my batteries so they sat ~1cm lower than in orig pic, above. Def in the market for some better, grippier, straps if you know anyone who makes them.
Saga rc makes them w/ kevlar although they were too wide for me to get thru the slots in the stocker battery tray
Lol so far so good after a few rolls but didn’t come close to sending it so only time will tell. Also worth noting I removed the closed cell bumper pad I normally keep under my batteries so they sat ~1cm lower than in orig pic, above. Def in the market for some better, grippier, straps if you know anyone who makes them. View attachment 236735
Looks great! I love those CRCU center braces so much but I haven’t talked myself into dropping that kind of coin yet.
