- 4x4-Mega
- Granite
- Infraction
- Kraton 6s
- Outcast 6s
- Senton 6s
- Talion
- Typhon 6s
- Typhon 3s
34/47 doesn't fit the stock mount went with 34/39 after 20 min running im only seeing temps of 140f with dual sky rc fans but on 100% throttle im cutting out due to my voltage dropping below lvc seeing large voltage spikes on my b-link gona lower my pinion size maybe some better higher c rating batteries34/39 will get hot for sure. Currently I’m running a saga 30t pinion with the 39t spur. Still gets hot pretty fast so I ordered a pps motor slider to be able run a saga 34t pinion with the factory 47t spur.
I have a very similar problem and I've yet to figure it out. Sometimes it doesn't happen, and I think I fixed it and then it just comes right back.lowered my pinion to a 29 running 29/39 still having hesitation at 100% throttle thinkin i need a higher discharge higher c ratied battery currently just eunning cheepo youme 6200mah 50c data log show during full throttle im dipping below lvc
What batteries did you use before? and this totally fixed it?
Haha I just got an o8s recently and I put in a max5 + TP5660 1356kv and I have it geared 31/47 with 2x 40mm alu frame fans and it's great. I was actually amazed by the temps tbh. I've only done wheelies and rips up and down the street pretty much nonstop but definitely impressed. Crazy considering my KV is higher than what most people run.Jeez i don't know how you guys are running these gearings and not frying everything. Was running a max5 and 1100kv hobbywing on 29/47 and it was getting hot all the time(granted florida but still) switching to lower kv motor gave better acceleration and cooler temps while,somehow, running quieter. kudos to you guys for even trying.
https://docs.google.com/spreadsheets/d/172JeLv4pGQYZ2fq2hMav_jhvPy5RMOYb2kBpuxgyUeY/edit#gid=0 check this outIs there a good tutorial on gearing that you guys recommend? Reading all these options 39t vs 47t etc make my head explode! Is there a gearing for dummies?
Yeah I had to switch to the pps motor slide deal to accommodate 34/47 gearing.
When you guys say the pinion doesn't fit what that mean? What is exactly the problem? Is it with the motor lengtWh or width? What pinion sizes do and don't fit? Is there a quick rundown on this?
