Kraton Keaton Diff shims
sdechiario
I just got a new Keaton BLX 6S and I am hearing everybody say “you need to make sure the diff is shimmed properly”. Do I drive it first them remove the diff or do I just remove the diff assuming it needs to be shimmed? Lastly, is there a way to check if it needs to be shimmed without taking everything apart?
You should look at the diffs before you drive. Even if shimmed properly, Arrma diffs tend to be notoriously known for being underfilled - so you might as well plan on topping off the fluids even if you decide not the check the shimming.
As far as taking everything apart, the diffs are pretty easy to get to and there are tons of videos on Youtube on how to get them out of the truck.
Uh Oh Oops GIF by CBC
