Kraton 6S (V4, but doubt that makes a difference), I keep destroying tyres.
I suspect most people know exactly what I mean, where the foam is sudden thrown out of the tyre.
I'm not doing speed runs, this is with the standard gearing, and mostly on grass. The car is not massively abused, but obviously accidents do happen, usually trees jump out in front of it.
I have vented the tyres as per Arrma's suggestion in the EXB manual (drilled 4 4mm holes in the rubber at 90 degree intervals, and taped over the hole in the rim).
Last run out was mostly on flat, mostly dry, short-ish grass, 1 battery pack, and it destroyed all 4 tyres.
Any suggestions, as at that alarming rate of £80 in tyres every battery pack, its not viable to use it.
