954kevin
- Thread starter
- #21
I certainly didn't take you any kind of way. I thought that was a great question and one I hadn't even considered. So, I appreciate you coming back with the follow up from them. I also bought the +1 driveshafts from M2C, just trying to get ahead of the common axle shaft pop-out issue. I watched a couple reviews of the Scorched knuckles where guys who had removed the red collar(common axle pop-out solution) were putting it back on with the Scorched knuckles saying the fit being better allows for it.Hope i didn't come off the wrong way yesterday with the questions.. I took woke up yesterday morning thinking about the Scorched hubs lol.
So they got back to me on the design question:
"The original parts are open too, through the 5mm hex hole – and completely open on the inside face, which is unavoidable. Ours will wear much better since we have the slippy Delrin liners rather than the glass/mineral filled stock plastic parts."
Also asked if the +1 shafts would be ok with them:
"Yes, they will be ok. Our hubs are very slightly narrower than stock (to help solve the same problem) – just check the shafts don’t bottom out in the cups – if they do you can just add a washer under the pillow balls"
I'll def take a close look to be sure they don't bottom out. I know that is just as bad as pop-out.
