Some good progress made today, coupled with a small setback and a dash of waiting on parts that were supposed to be here last Thursday(thanks Jesus).
I got the dual fan setup from Campfire carbon installed along with a couple 40mm Rocket fans. I have primarily used the chunky 40mm server fans as upgrades, but I didn't think they would fit under the shell utilizing the oem heatsink and dual fan adapter plate. So, I am trying the famed Rocket fans for the first time. I'm a little skeptical, but at the same time, I'm certain they outperform the the stock fan. Everything looks nice and tidy.
Second, I was able to install the titanium motor mount bolt/screws from RamJam Racing. There was some modification required to the upper cage for clearance. I don't think there is any kind of structural compromise, but the bolts are totally acceptable and the cut-out looks nice and clean.
Finally, I got the kevlar straps from Garage Life RC installed. I cut the built in hoops off the bottom of the battery tray because these straps were too big to slide through it. The battery is really secure and I imagine the whole tray is going to break off the chassis long before these straps give way or need replaced. If the effort needed to get this pack back out of the tray once it's tightened down is any indication, I should not need worry about battery ejection.
The set-back I mentioned concerns the servo mount from TREAL. The back corner is juuuuust touching the center driveshaft. I don't think the driveshaft has enough movement to get into the servo mount enough to cause anything other than superficial surface marks, but it bothers me. So, I plan to take the servo mount back out and grind or file that closest edge back a couple mm for better clearance.
If you made it this far, maybe you can tell me what these extra two unused countersunk screw holes are for towards the back of the battery tray... Is there a longer battery tray that fits in here?
