Kraton 4s body swap?
aiden
Outcast 4s
I think you can but you will have to make your own holes and it won’t fit perfectly. I have never done it before.
RecklessRC Bashing
Colorado
Granite, Kraton 6s
Can an outcast body fit on my Kraton 4s?
The outcast body is shorter than the kraton as with the whole wheelbase. You’d be talented if you got it to fit without looking weird. If you try it, Please let us know how it came out. Good luck!
NewSensei
Military Veteran
Fort Worth, Texas
4x4-Mega, Kraton 6s, Senton
Little plexiglass to extend and badda bing, it'll fit, just look a bit junk yard ;)
CameronCodes
Maine (downeast)
Kraton 4s
Thanks. Also I was looking to paint mine satin kind of like the the arrrma drift truck that's name I can never remember. Every other body out there has kind of a glossy look to it. Does the drift truck get painted on the outside or something?
RecklessRC Bashing
Colorado
Granite, Kraton 6s
If you’re talking about the infraction, I’m almost positive it’s painted on the inside with matte paint. If it was painted on the outside the paint would get ruined quick.
NewSensei
Military Veteran
Fort Worth, Texas
Painting on the inside will make is shiny on the outside. If he's wanting to go matte the best option is to etch the outside and paint the inside. You can take the shine away from lexan with some good paint thinner, you just have to make sure you get it coated evenly and not too heavily, runs will show in the etch but if you can spray it on evenly it will etch the plastic nicely. You can also use a matte clear coat on the outside if you wanna make it easier...
At any rate, I wouldn't put color on the outside of the body as when it gets damaged it will show a lot more than if the color is on the inside with an etched or clear coated outside ;)
CameronCodes
Maine (downeast)
Kraton 4s
So that's why the infractionsame body looks so different, because they use thinner on the body and etch it? It's the only on that I've ever seen that doesn't have any shine on it.
NewSensei
Military Veteran
Fort Worth, Texas
Not sure how they etch to be exact but I'm betting it is a mask and spray a solvent method since I think that's the only way to get the nice matte without paint...
NewSensei
Military Veteran
Fort Worth, Texas
Can you recommend me a good painter, preferably from the forum.
Painting is pretty easy, you just need to get paints that adhere to lexan. This was my first attempt trying to paint my own body using Rustoleum paints...the red did not adhere well, look closely at the top and you'll see it pulling away, Rustoleumisn'tgood for lexan apparently :(
That said, all I did was paint the front black and tried to "fade" as much as possible then painted the red on top of that. I like the look if it weren't for the paint bubbles so may try again in the future...
My suggestion is if you want matte on the outside to etch first. Just tried with a paper towel soaked in acetone and that seems to work pretty well but you gotta wipe evenly and at an even pace ;)
EDIT: forgot to add, you'll never get good yourself if you have others do it for you. Even if it doesn't come out perfect it can still look good with stickers ;)
Create account
Log in
