Kraton kraton 4s chassis
paul shipley
evening all. having snapped the front of my chassis tonight. can anyone reccommend a UK based replacement pretty please
Well you can go on custom rc upgrades and get an upgraded chassis or go on bad touch breakers for a way stronger chassi than stock
Get a tbone bumper for the kraton or a rer bunper of a typhon 3s thats what inuse on my kraton added foam between the stock bumper and the t bone(bolted the bumper on top of the original).
I feel your frustration I snapped my front twice and the rear once I have been working on the chassis I made a chassis brace. Now I'm working on my second one
@dmazda, very nice. Not for nothing but you do not have the flex you get with plastic arms vs aluminum. This transfers impacts to other weak areas. Especially in the 4s line up. I’m wondering with the revamp of the 4s line up we’ll see more aluminum integrated with the chassis. I need to get me some countersink bits. (y)
By the way this my first truck, I learned alot about this truck I upgraded almost everything. I'm working om my second one now after the rear cracked on me.
Found out that the center brace does help with the chassis if you remove the brace, try flexing inward you see the shock towers move inwards too so chassis will crack. I Removed the brace and my own. I have tons of pictures
I have put the 4s electronics on my typhon 3s ran with the stock tires big mistake its crazy fast now it was a monter but my pinion being worn it was screaming hard in the jump it loves to catch the air ahd go funky well i landed on my wing so hard that one side of the chassi cracked. Surgery time i have used superglue and thick shoegoe layer to save the chassi like i did with my kraton on my original chassi after hitting a pole sideways
i think im going to stick with that and sell the outcast as a roller i want to put the tower to tower brace but i cant make a perfect cut on the mody like this guy did
I'm almost finished with second project couple of thing to finish this is I have now
