I run on grass with my 4s kraton anc i can touch the motor without burning myselfIf you want a smaller/shorter truck, go with the outcast 6S.
Longer trucks drive better/easier though.
I have an outcast 6S and a stampede 4x4 vxl on 3S. The outcast does great pretty much anywhere, grass bmx track, various parks or the skate parks. The stampede does best with very very short grass and skate parks. The 4S outcast/kraton will likely struggle a bit/run hot like my stampede if you run in grass that is very long.
You run on 3S or 4S?I run on grass with my 4s kraton anc i can touch the motor without burning myself
The crap venileon motor is know to over heat.. i remeber running during the snowy winter on 3s 7000mah stock pinion i could melt ice and make it boilYou run on 3S or 4S?
What size pack do you use?
I run on 3S in my stampede with a 7200mah pack, 3100kv 3665 motor and it gets up to 150F pretty easily in the grass. Could be the steel diffs, MIP X-Duty axles and 2.8" trenchers adding load as well that isn't helping.
I'm running a HW Max10 sct and Hobbystar 3665 3100kv motor. I also have a motor fan.The crap venileon motor is know to over heat.. i remeber running during the snowy winter on 3s 7000mah stock pinion i could melt ice and make it boil
And in the summer it was worst i had to buy a fan
My kraton runs stock motor and 13t pinion
And i run a 4000 mah 40c 4s
