Jluther@becoinc
- Senton 6s
- Talion
Anyone know how to put sway bars or something else that would be like droop screws on the kraton 4s?
Good question. I'm sure it's possible to add sway bars not sure the easiest way to do it though. I don't think that droop screws are possible though.Anyone know how to put sway bars or something else that would be like droop screws on the kraton 4s?
Yeah I know droop screws are not a possibility but I would like to be able to take the load off the shocks and keep the front end from stretching up on exceleration. I would think it would help the truck turn better. I was thinking about maybe a shorter shock not sure how that would doGood question. I'm sure it's possible to add sway bars not sure the easiest way to do it though. I don't think that droop screws are possible though.
Maybe you can rebuild your shocks with more rebound.Yeah I know droop screws are not a possibility but I would like to be able to take the load off the shocks and keep the front end from stretching up on exceleration. I would think it would help the truck turn better. I was thinking about maybe a shorter shock not sure how that would do
I want it to maintain a low center of gravity so that the a-arms stay level not ride higher or raise up during acceleration Maybe a shock limiting strap like some people put on revos to keep the shocks from pulling apart I’ve seen those somewhere just don’t know where or exactly what they are calledMaybe you can rebuild your shocks with more rebound.
Sorry the long sen tenceI want it to maintain a low center of gravity so that the a-arms stay level not ride higher or raise up during acceleration Maybe a shock limiting strap like some people put on revos to keep the shocks from pulling apart I’ve seen those somewhere just don’t know where or exactly what they are called
