Shottah
- Points
- 83
- Kraton 4s
Hey all,
Got my first RC car this week, its the Kraton 4S V2.
Ive read that i should check the diffs for oil and shim them if necessary while im at it. But i am having a hard time figuring out which shims i should get. From the explode view page i believe these AR709052 ( https://www.arrma-rc.com/en/product/washer-12x15.5x0.2mm-4/ARAC9937.html ) are the ones to shim the ring gear but i am not 100% sure. There doesn't seem to be a stock shim on the pinion gear so i cant figure out which shims to get for that if it is even needed ? Also what kind of grease would you recommend to go on the diff after finishing up ?
Hope someone out here can help a noob out.
