What do you mean? Do you plan to replace it?Wats a good battery tray to use for the kraton 6s
I would have to agree with that lmao from wat im readingThe one that it comes with.
Yea but it seems like the stock one is the best. Sometimes i use 2 3s batteries and they don't fit to goodWhat do you mean? Do you plan to replace it?
Yup, i would have to agree lokMy only complaints with the stock battery tray are that it should screw to the chassis, ie the holes in the chassis should be threaded and you put the screws into the chassis through the battery tray and it needs to be like 5mm wider and a lot longer.
