Here is a short video of what the servo was doing. I'm new to the Arrma world so if there is a way to resolve this im all ears! Or is this servo shot? Bought this new little over a month ago.
Was that a direct replacement fit?? I do a lot of high jump type bashing (into sand or grass) and tons of dirt type stuff. I don't mind paying a little extra if it means more durability, anything really in the sub $100 range would be my ideal budget for a servo.Many, including me, run the DS3235 servo.
savox 1210sg waterproof I have 3 and not one has gone bad yet had them a few yearsWas that a direct replacement fit?? I do a lot of high jump type bashing (into sand or grass) and tons of dirt type stuff. I don't mind paying a little extra if it means more durability, anything really in the sub $100 range would be my ideal budget for a servo.
Yes, direct fit. I recommend getting an aluminium servo housing from Amazon or Aliexpress to reduce play in the servo housing, especially with an upgraded servo (the stock servo is too weak).Was that a direct replacement fit?? I do a lot of high jump type bashing (into sand or grass) and tons of dirt type stuff. I don't mind paying a little extra if it means more durability, anything really in the sub $100 range would be my ideal budget for a servo.
do not buy that servo it has significantly less torque than the stock and cant even make use of all the power the car puts out (only 6 volts). it would be like buying street tires for offroad use.Would something like this fit?
ProTek RC 100T Standard Digital "High Torque" Metal Gear Servo
https://www.amainhobbies.com/protek...high-torque-metal-gear-servo-ptk-100t/p228478
Listed for $50 bucks on Amain and thinking of getting a 25t aluminum servo horn to go with that.
Ended up going with the Savox SW-1210SG one instead.do not buy that servo it has significantly less torque than the stock and cant even make use of all the power the car puts out (only 6 volts). it would be like buying street tires for offroad use.
You would have been better off getting the Powerhobby 729mbl servo that I posted. Around the same price as the Savox but has significantly more torque and speed, plus the Powerhobby servo has a brushless motor as compared to a coreless motor on the Savox. Also, Savox servos are notorious for being power hungry servos. Hence the need for the "glitch buster"Ended up going with the Savox SW-1210SG one instead.
Yea I was torn between the 2 really, both of my buddies have a Savox type for a servo and they are both extreme bashers so I went with that. At least now I have another go to if the one I got fails haha.You would have been better off getting the Powerhobby 729mbl servo that I posted. Around the same price as the Savox but has significantly more torque and speed, plus the Powerhobby servo has a brushless motor as compared to a coreless motor on the Savox. Also, Savox servos are notorious for being power hungry servos. Hence the need for the "glitch buster"
Yes, the HR servo horn and link will work.Yea I was torn between the 2 really, both of my buddies have a Savox type for a servo and they are both extreme bashers so I went with that. At least now I have another go to if the one I got fails haha.
I'm eyeballing this, would this be ideal for the new servo?
Hot Racing Arrma Kraton/Outcast Aluminum Fixed Link Steering w/25T Servo Arm
i was told that thing is a PITA. so just get a 25t arm servo horn. and part # AR340061Yea I was torn between the 2 really, both of my buddies have a Savox type for a servo and they are both extreme bashers so I went with that. At least now I have another go to if the one I got fails haha.
