Kraton Kraton 6s BLX tires
RC_Noob
SoCal
Anyone know the weight of the tires that come on the Kraton 6s BLX (or EXB if they are the same). I believe they are the dboot copperhead mts. I know the stock weight of the BLX rtr is 10.67lb and was looking to put on the Talion EXB dboot belted qatar ones on there. Or anyone know the weight of the dboot qatars (the ones from the Taltion EXB).
Just a running list of the tires I've either had myself or got weights from others for. If you have the weight of something not on the list, let me know and I'll update it.
The ones listed as mine were weighed on the rim on a USPS scale that only does oz. I converted to grams and lbs.
Tires: 50BrandTireBeltedRim/IDOffsetODOzGramslbsMine
TireArrmaDboots Ragnarok AR550053N2.806.138174.010.38N
TireArrmadBoots Hoons 43/100-2.9Y2.903.916111.000.24N
TireArrmadBoots Hoons 53/107-2.9Y2.906.596187.000.41N
TireArrmaBackflipsN3.81/417212.500354.370.78Y
TireArrmaBackflips LPN3.81/41549.875279.950.62N
TireArrmaBackflips LP on Traxxas 8671N3.81/215410.000283.500.63N
TireArrmaCopperhead 2N3.81/411.625329.560.73N
TireArrmadBoots FIRETEAMN3.1/3.8?16912.980367.980.81N
TireArrmaKatar (talion v2/3 stock)N3.81/41457.160202.980.45N
TireArrmaMinokawa LP (Kraton 4S)N3.81/49.350265.070.58N
TireArrmaMinokawa Mt (Kraton v3)N3.81/410.500297.670.66Y
TireArrmaPincerN3.81/411.640329.990.73N
TireDuratraxSix Pack MT - DTXC5604Y2.81/28.395238.000.52N
TireDuratraxSix Pack X - DTXC5502 (XMaxx)Y4.3?~8"27.267773.011.70N
TireDuratraxx-cons truggyN41/21449.700275.000.61N
TireGRPGRP GTX01-S5Y3.89983.06987.000.19N
TireGRPT01 REVO (S3 compound) beltedY983.07287.090.19N
TireJetKoSuper Sonics MT StreetY3.81/215.556441.000.97N
TireLouise RCST-ViperN3.8016.150457.841.01N
TireLouise RCT-ApolloN3.808.750248.060.55N
TireLouise RCt-rockN3.809.060256.850.57N
TirePowerhobbyScorpion beltedY4.51/45.813.000368.540.81N
TirePro-lineBadland MX 2.8N2.87.619215.990.48N
TirePro-lineMX28 HP beltedY2.85.026.349180.000.40N
TirePro-lineTrencher 17mmN2.87.100201.280.44Y
TirePro-lineTrencher 17mm beltedY2.81/28.466240.010.53N
TirePro-lineBadland 17mm - hub insertsN3.809.200260.820.58N
TirePro-lineBadland 17mm - standard hubN3.808.600243.810.54N
TirePro-lineMasherN3.8013.157372.990.82N
TirePro-lineMX38N3.8016.089456.121.01N
TirePro-lineMX38 beltedY3.8014.740417.870.92N
TirePro-lineRoadRage 1177 desperado 17mmN3.81/29.375265.780.59N
TirePro-lineShockwaveN3.809.900280.660.62N
TirePro-lineSlingshotN3.809.277263.000.58N
TirePro-lineTrencherN3.8013.400379.880.84Y
TirePro-lineTrencher LP - hub insertsN3.809.800277.830.61N
TirePro-lineTrencher LP-plastic hubs wrappedN3.81/210.000283.500.63N
TirePro-lineTrencher XN3.81/213.651387.000.85N
TirePro-lineTrencher X beltedY3.81/216.967481.011.06N
TireRCStation-Amazon17mm .5" offset MT (maybe more offset)N3.81/29.400266.490.59Y
TireRedcatKaijuN?1/25.8"10.120286.900.63N
TireSP RacingSP-GT-50 (50 shore)N1/2982.58873.370.16N
TireThunder TigerMT4 G3 17mm keyed hexN3.81/212.500354.370.78Y
TireTraxxasMaxx 4S 17mmN2.88.200232.470.51N
TireTraxxasSledgehammer 2.8 (12mm hex)N2.88.200232.470.51N
TireTraxxasSledgehammer 2.8 (17mm hex)
front/rear ID's differ
N2.89.800277.830.61Y
TireTraxxasChevron 3.8 on GeodesN3.81/2"10.000283.500.63Y
TireTraxxasMaxx AllTerrainN3.8011.500326.020.72Y
TireTraxxasTalons v1N3.809.100257.980.57Y
TireTraxxasTalons v2 EXTN3.81/2"13.900394.060.87Y
Super helpful list here from @olds97_lss
