Kraton Kraton 6s center diff. Am I missing a washer?
Custnam
North Bay Area California
  2. Kraton 4s
Swapping out bearings and changing fluids on my brand new Kraton 6s and noticed the center diff looks like its missing the washer that covers the o-ring. This is how it was when I opened it. Center on left. Rear with washer on right. Just want to verify Im missing that washer. Thanks
Yas
UK
  1. Notorious
  2. Outcast 6s
  3. Typhon 3s
Yep! That o-ring should be covered by a shim
Instead of the OEM shims anyway, use the Mugen Seiki shims instead, part #E0206
Engineer
ArrmaForum Fan
NE Ohio
  1. BigRock 4x4
  2. Felony
  3. Infraction
  4. Limitless
  5. Kraton 6s
  6. Kraton 4s
  7. Senton
  8. Talion
  9. Typhon 6s
  10. Typhon 3s
Does the Mugen kit come with all the shims Ill need if I buy one? And whats the difference with these vs stock?
yes - it should come with six large shims that go under each of the sun gears and 12 small shims that go behind each planetary gear.
the sun gear shims are large in diameter and will cover completely behind the sun gear - also seem to be of higher quality than the factory shims
Yas
UK
  1. Notorious
  2. Outcast 6s
  3. Typhon 3s
Yes it does:
x6 planetary shims (2 for each of the 3 diffs)
x12 satellite shims (4 for each of the 3 diffs)
The stock satellite shims are okay to keep in though so you can keep the Mugen ones as spares
However it may be a good idea to get at least 2 packs as they can be a bit tricky to get hold of. They're fairly sought after
Jordan10R
Hey do u keep that little shim and put the big mugen shim over? Or do I just replace the little one with the mugen one?
Engineer
ArrmaForum Fan
NE Ohio
  1. BigRock 4x4
  2. Felony
  3. Infraction
  4. Limitless
  5. Kraton 6s
  6. Kraton 4s
  7. Senton
  8. Talion
  9. Typhon 6s
  10. Typhon 3s
In general, replace - but shimming isn’t an exact science so if there’s still play then you might have to add more shims
Jordan10R
Just curious. I know I have to add one on top and replace bottom or other way around but top and bottom to tight
Custnam
  2. Kraton 4s
OK. I ordered the last set of the Mugens I saw on Amazon. Should be here on the 13th. I also ordered some stock ones too just in case. I guess with all the possible things that can be wrong in an RTR its not bad thats its only missing a washer. It wasnt leaking anywhere either. And although I did run into some parts that needed a soldering iron to loosen the overdone thread lock I was able to get the entire truck apart with no stripping screws or any broken parts. Shocks were built perfect so I don't need to even touch those. But once I have the washers I need Ill be filling the diffs with 60K F, 200K C, and 30K R.
