Seems to be a solid setup. Lots of people here running that.60k-70k Front, 200k-500k center, 20-30k rear. The rig will liven up. Less power bleed from rear to the front (much less ballooning). Overall there will be less wear to your diffs. The lower numbers represent where I started and I ended up with the Bold highlighted weights. I'm good with them. I must have rebuilt these 6S diffs 30+ times . Make sure to shim properly. That's another topic and been discussed many times elsewhere on AF.
Good luck trying to find Oil. Its been hard to find. I like Team associated and Losi diff and shock oils. But beggars cant be choosy these days. Just food for thought.
My swb Noto runs great with that setup.Seems to be a solid setup. Lots of people here running that.
F:60 C:500 R:20 is what I run in my kratons.
Yeah. Freakin' weird. I noticed diff fluid shortages a couple of months ago when I went looking for some. Expecting the EXB to arrive and wanted some 100k on hand for that thing. A lot of stuff that's out there have the prices jacked up a bit. I went to JTP for my 100k, but unfortunately that's the thickest he has.With the lack of inventory due to both covid and the drag racing community sucking up all the 200-500k diff fluid, best I could come up with for the middle was a tube of 125k in my track bag.
It's a v3 talion currently only running around fields/dirt lots and roads mainly so no need for super backflippy 500k center stiffness.
I have 125k, 60k, 30k, and 15k.
Figured I'd do 30/125/15 for the time being. Not huge improvement but better than stock and I have to refill them anyways regardless.
I would go 60K in the front from the get go. 60f,125c,15r.With the lack of inventory due to both covid and the drag racing community sucking up all the 200-500k diff fluid, best I could come up with for the middle was a tube of 125k in my track bag.
TA oils should be back in stock early December from sites that show their ETA.Yeah don't waste your effort/time with 30k in the Fr. Go right to 60k/ fr, then 30k in the rear. 60k will spare your front tires from ballooning much left and right. Then you are pretty much set. 125 will be fine in the middle for now. Drive it . Then when you find 500k, use that in the center. Stock Ctr. is 100k for reference. 2:1 ratio front to rear seems ideal for me. You Just need to search for 500k. 200k may work for you also if its all you can find. I ended up finding Traxxass 500k. Expensive because you get such a tiny bottle. But that s all I found. Its fine. TA oils are hard to find. But that's mostly what I used for years.
60/1m/30I'm running...
70k / 150k /40k
