parcou
Hospitality Award
Rig of the Month Winner
- Memphis, TN
- BigRock
- Felony
- Fireteam
- Granite
- Infraction
- Kraton EXB
- Talion EXB
- Typhon TLR
- Vorteks
I could be off on the title so please correct me if I am wrong with the following
My K6S EXB came with an LSD rear but I want to try an open diff to judge the difference in performance. The kit is ARA311094.
I followed the diagram to the letter but found after I got it all together and turned the outdrives they did NOT turn. They were locked and if I backed off the 4 screws a bit it would turn until I tighten again. I think I read where someone could have been @jondilly1974 to use your own shims and not Arrma, JD sorry if this was not you and I misquoted.
The issue with kit ARA311094 if you take:
larger shim right above the o-ring + spacer = ~2.06mm (shim in the middle was between the spacer so had no play in the height)
The spacer sat on the large shim to it added to the overall height. It took me a min to figure this was the issue
Stock with the LSD stars:
stars (all 3) + large shim = ~1.94-1.96mm (again the other small shim is between the stars so does not add to the height)
To fix the issue, I needed to remove the large shim so the spacer could sit flat on the diff bottom and not in it. What I needed up with:
spacer + 0.1mm shim = ~1.96-1.98mm
ARA311094 kit says the spacer is 1.9mm in height but I never got that anytime I measured it on I got ~1.86-1.88mm. The 0.1mm spacer I used was from a TRB shim kit a 12x16.01mm and all that came to the ~1.96-1.98mm which was in the range of the OEM with the star LSD plates.
How I placed the 12x16.01mm shim was sun gear then placed the shim under the bottom since there was a lip on the sun gear. Then placed the spacer onto the sun gear to sandwich the shim.
I am open to any corrections if I got anything wrong, but I hope it helps someone else or others add to correct what I found This gave me a very smooth rear open diff. FYI - it did work without the 12x16.01mm however I just did not feel any gear resistance when I turned the diff, felt nothing on the inside. Adding .01 did give the slight feel I was looking for and felt more like when I finished an Infraction diff to have the slights, faint internal tick.
