Sounds like you have it over-filled. Take the grub screw out on the side of the housing, rotate it so that hole is up, and then tighten it. If it is still locking up when tightened you have too many shims or something is not fitting together properly.So I’m getting this lockout of the diff often (or just way too stiff action that “pops” or jumps as opposed to the smoother chatter or click of the LSD effect) when I tighten the screws down final. If I loosen them just a little the diff feels fine and all is good, so I know there isn’t a damaged gear causing bad mesh or anything. It’s definitely just the compression of the system when screwed tight. I’d just go with loosening them but oil is leaking from the screws when I do (doesn’t take much loosening for oil to dribble out). I’m about to try this “cracking” method but obviously a little nervous as this doesn’t sound normal at all. Not to distrust you here spoc but anyone else confirm this is a safe and logical maneuver? Typically I’m against brute force methods just cause it shouldn’t be necessary.
