Sococapricorn
Hello does anyone know the pitch for the center diff spur gear on the EXB Kraton 6S I know it's 50T but what pitch?
It depends on what motor you are putting in and what cell count you plan to run. I run anywhere between 15-25t on my trucks but they have various systems in them.Ok was curious cause alot of sites say a tooth and a pitch and I was like ummm idk the pitch.
Ok so does anyone have a good recommendation for a 6s EXB center diff Spur and Pinion set up?
25.4 pitch is not really standard for an RC pitch.Mod 1
Or standard 25.4 pitch
edit, but if you need a pinion just do as stated search for mod 1 with 5mm bore or if you have a motor with an 8mm shaft mod 1 with 8mm bore
Im buying Tekno pinions now. Tired of stressing if I will strip it when I remove the screw.I like to run Tekno pinions they have a 4m instead of a 3m grub screw making it less of problem with them backing off and tighter hold on the shaft.
As for spur the 50T spur stock is what most run Vitavon sells a 44T spur but I only know of this being needed when going over 25T pinion on stock motor mount and or running a 56xx motor and running like a 35T pinion.
Stock motor mount only lets to go to a 75T total tooth count.
Up to a 25T mod 1 pinion will fit on stock motor mount with the 50T spur but heat and load on motor should be considered. The talion EXB comes with a 25T high speed gearing and runs hot with its smaller tires. With something like a kraton tire that is larger I would on stock electronics not run a 25T pinion IMO if you have like a max 6 hobbywing combo or something like this then 25T should be ok just watch your temps.So with the Mod 1 50T I can run any pjnikn 15T to 25T and be ok?
+1I like to run Tekno pinions they have a 4m instead of a 3m grub screw making it less of problem with them backing off and tighter hold on the shaft.
Yeah 18 is probably borderline for a 1650kv. Large Mt tires/6sI use a 18 tooth pinion on my kraton exb with the Hobbywing 1650kv motor and it runs a little warm on hot days but not bad.
How would you say 18t pinion is for bashing. Does it give it the speed and Torque?Yeah 18 is probably borderline for a 1650kv. Large Mt tires/6s
What's your setup? Motor? Esc? 6s? Motor fans? Many variables to consider here.. stock is 12/50. Without knowing what your specific setup is, I say run the 12/50. Get yourself a temp gun if you don't already have one because running bigger pinions is going to heat things up. Better safe than sorry.How would you say 18t pinion is for bashing. Does it give it the speed and Torque?
In theory, you sacrifice one for the other..smaller pinion, more torque and less top speed.How would you say 18t pinion is for bashing. Does it give it the speed and Torque?
