Hi everyone,
Im looking for some help or advice with a problem that I have with my KRATON 6S. I bought the RC in October 2019 and shortly after it began to throw the front drive shafts out of the drive cups. This has caused damage to the A arm and cups. It normally only does it when I operate it at 100% power setting but has done it on the 75% power setting. It is still under warrantee so I took it back to the shop that I bought it from in Brisbane (now closed) and they showed very little interest and the only advice that they offered was to remove the small washers between the A arm and the ball joint screw. This made no difference as the washer is less than 0.5mm thick and I need to gain around 2 to 3mm. I went to another RC shop who do not sell KRATON and they were very helpful but only suggested that I trim a couple of mm of the end of the A arm so the drive shafts can fit further into the drive cups. I do not like this idea and do not think that I should have to make such a modification to fix a problem that should not be occurring in the first place. I have attached a photo showing how close the drive shaft comes to the edge of the drive cup. This is after I have removed the washers so prior to this it came even closer
Has anyone else had similar problems with a KRATON 6S and what action was taken to fix the problem. Your advice or assistance would be greatly appreciated.
