Pitmasterbernie
If I strip my input gear on my 6s Kraton, should I change both the input and crown gear or can I get away with just changing the input?
It stripped because my diff case cover was loose due to strippin 3 out of 4 screws on a hard rear landing.Just the input also check if the a spacer on the outside of the diff that normally causes it to strip
