alanbenton1028
I've been doing a ton of reading on here, which has helped assist with my Notorious to Kraton build. So for the new ESC, I went with the Max6. For the motor I chose the Hobbystar 4092 1730kv. My question is what size pinion gear am I going to need to run? I'm always using a 6s battery, and I like to do a pretty even mix of bashing and speed runs, as my surroundings are mostly concrete. If someone could help me out, I would be forever appreciative. Also, I need to know not only the number of teeth for the pinion, but what pitch, or whatever....? What do I need to search in order to get the correct gear? Thanks in advance. Oh yeah, my build consists of a Notorious 6s, that's going on a Kraton 6s M2C chassis, Basherqueen carbon fiber shock towers, t2t brace, steering pieces, stainless steel screw kit, and a few more pieces that are yet to come. I'll post some pics once I'm about to start.
