Todd Packer
Just picked up one. Anyone have any suggestions on gearing? Was thinking of putting in a 23T pinion.
I just want a little extra pop.
What electronics are you running? If stock, that’s waaaaaayyy too big of pinion.Just picked up one. Anyone have any suggestions on gearing? Was thinking of putting in a 23T pinion.
Yeah it’s stockWhat electronics are you running? If stock, that’s waaaaaayyy too big of pinion.
6s6s or 4s?
Yes! I blew up a stock tire on 15T! Gotta be careful when a front wheel comes off the ground in a spin and gets all the power.6S and 20T (speed pinion) is the absolute max and you will cook the motor in 5 min.
23T will just burn it out.
You want to stay around 15-16T for bashing, 14T in grass. Add a fan and you can gear up 1 or 2 teeth.
In addition, higher pinion makes no sense as you will blow out the stock tires starting around 20T.
i run 25t on a 4985 and my fronts balloon all the time. Never shredded a tire yet. If this guy runs a 23t hes gunna cook his electrics before he has a chance to shred a tire.Yes! I blew up a stock tire on 15T! Gotta be careful when a front wheel comes off the ground in a spin and gets all the power.
Oh, and that was with 1M centre. I think it was just bad luckYes, you would want to change your diff oils. Stock is very loose and 1 lifted wheel will result in a foam explosion
Deletei run 25t on a 4985 and my fronts balloon all the time. Never shredded a tire yet. If this guy runs a 23t hes gunna cook his electrics before he has a chance to/ shred a tire.
?Delete
I deleted what I said. Thanks for the info
