https://www.amazon.com/dp/B0872CRKJD/ref=cm_sw_r_cp_apa_glt_fabc_MV8ZB04EC649G3TTDFJJLooking to upgrade my servo mount and servo in my kraton 6s. Any recommendations? Not looking to spend a paycheck on a servo just to bash with though![]()
Yea not bad servo for the priceI put that exact set up in my Typhon 6s and it really tightened up the slop I was experiencing in the steering
Probably will do the same for Kraton EXB that’s on its way
Sweet, this is exactly what I was looking for. A nice, affordable servo. Seems to be a lot of great reviews about it out there for the price.https://www.amazon.com/dp/B0872CRKJD/ref=cm_sw_r_cp_apa_glt_fabc_MV8ZB04EC649G3TTDFJJ
I run this one In my notorious. But there is a cheaper one to and just a hot racing mount. View attachment 143850
I'm definitely going to look into this one a bit,If you have the plastic servo mount, the cheapest fix is to run extra long screws. As stable as any alu version.
Servo for the budget is a DS3235kg on Amazon.
https://www.amazon.com/Beffkkip-Dig...child=1&keywords=DS3235&qid=1620168928&sr=8-1
Order from china for half the price but a longer wait.
The link shown in the photo is key also I believe in tightening up the linkage.I'm definitely going to look into this one a bit,
I'm gonna compare it to the ecoboost servo. And I never thought about running longer screws I to the mount.
I appreciate the help,
Quick question, looking at your pic, it doesn't look like you needed any spacers between the servo arm and the steering right? I did a similar upgrade recently with different servo but it raised the height of the servo arm so it didn't align well with the steering system so I had add some spacers which I'm not too happy about. This setup looks like it aligned perfectly, I might get the same servo if thats the case... Is the servo still working well for you?https://www.amazon.com/dp/B0872CRKJD/ref=cm_sw_r_cp_apa_glt_fabc_MV8ZB04EC649G3TTDFJJ
That servo is super nice works great. Little pricey but works great. And yes I have a little nut in there for spacer. I'll take a close up pic. When I get home from work. But how I got set up works greatQuick question, looking at your pic, it doesn't look like you needed any spacers between the servo arm and the steering right? I did a similar upgrade recently with different servo but it raised the height of the servo arm so it didn't align well with the steering system so I had add some spacers which I'm not too happy about. This setup looks like it aligned perfectly, I might get the same servo if thats the case... Is the servo still working well for you?
Yea mine wouldn't turn on ground till I added snap ringsJust put a DS3235kg on my kraton with the EXB mount. Not real impressed with the power of the servo. Won't turn anywhere near full lock sitting on the ground, only turns halfway decent when I'm on the throttle. And no the servo saver isn't eating up the travel.
