DESTROYER1445
- Kraton 6s
Ok I'm running a stock kraton 6s v3 with paddles at all 4 corners on a sandy track with the stock 12/50 gearing the motor gets pretty hot so I dropped to 10/50 and it got better but I'd like to get some speed back plus who doesn't want more horsepower
I've been reading a bunch of threads on the subject and it seems like to get more power and torque you need a bigger diameter and or longer motor and that usually has a lower kv so then you gear up to compensate for the loss of rpm
So my question is how do you balance getting a bigger lower kv motor with higher gearing without ending up back to square 1 as far as heat issues go
