So I've been trying to improve the steering on my Kraton 6s V4, in doing so I've added snap rings which seemed to help for a short while. I also changed front diff oil from the 60 cSt weight to lower 30cSt to see if that would help and sall no real difference there. Now I'm trying the HR aluminum steering bellcrank,
I found the stock parts had a lot wear for a rig that is only 4 months old IMO here is picture of new from Jenny's compared to used
also I was not expecting to find the shaft to be worn out either
there is .60mm wear new is 11.90 this one has spots that are 11.30 also here's picture of old bellcrank which has a ton of wear as well
still putting everything back together as of now but hope to get to take it for a test run tomorrow and praying it's going to be much better
