joaokrm
- Points
- 73
hello guys, I've turned my kraton 6s v5 blx into a on-road car and I just blew my center diff.... (I think that off-road cars are way better than on-road cars with slick tires)
I run my kraton only on asphalt, the tires has a lot of grip and I'm gonna upgrade the center diff to a stronger one (all metal), center diff mount (all metal too) and adjustable servo saver.
The center diff that I'm about to buy has already 300k oil, what do you guys recommend for me? I'm thinking to use 100k/300k/50k (front/center/rear) for asphalt only. I know that probably I will need to buy a metal case for the front/rear diff too.
This is the diff that I will gonna buy:
https://a.aliexpress.com/_mN7KR8g
And this is the diff mount:
https://a.aliexpress.com/_m00Bb9w
And, the oil that I will use:
https://a.aliexpress.com/_mtkA9iG
Upgrades that I currently have:
Standard upgrade Dumbo radio;
Slick rubber tires;
Not really and upgrade: X-Team 4082 2000KV Motor with 20T gear (stock ESC, lowest timing possible);
Savox SV-1270TG Servo.
Slick rubber tires;
