Good day Arrma fam
I've recently got an Arrma kraton 6s v5 ... after about 10 battery packs ... ive noticed after about 10 minutes of riding time when I hit the breaks its starts clicking... not grinding tho .
I've checked all the gears and diffs ... ive changed the front input gear and I've shimmed the diffs .. the front input after removing it was still fine and didn't need replacement... but I changed it anyway
But the noise doesn't go away ... initially when riding there's no noise but it comes in a bit later on ... also once it starts making the sound when braking it also makes it in reverse... but not moving forward ... ive check everything I could visually and it all seems fine ... ive checked the motor mesh and all drive train gears and they are all perfect.. ive also tightened up eveything i could .. any idea what could be clicking ... only on braking and in reverse after 10 minutes of riding time ....
