SaltyLocal
My stock Kraton V5 servo is shot so I’ve decided to upgrade while I’m replacing the servo. I’m still shopping for a quality, waterproof servo if anyone has any suggestions. Anyways, I been watching some videos and it seems many replace with a 25 tooth servo arm as well as a aluminum mount.
My question is: are the Hot Racing Servo Saver the same as the steering bellcrank linkage? If so, is the linkage the part that has washers and is recommended to change to ball bearings (does the V5 have bearings instead of the washers)?? Does the servo saver (or linkage bellcrank), aluminum servo mount, and bearings all needed to upgrade in the V5 RTR? Basically, what should be upgraded since I’ll be replacing the servo? Thanks forum members!
Edit: are Hot Racing parts of quality or should I be looking at a better brand?
