Casper391
- Granite
- Kraton 8S
- Typhon 3s
Received my Kraton 8s and have ran it 1 1/2 times. First drive was no problems. I was just driving around in the front yard and up and down the street just getting used to it. Second set of batterys was the same just putting around in the front yard for less than 10mins. I had to do something in the house so I parked and turned the truck off. When I came back and turned it on the ESC would not go through it start up flash/beeping/cell check. All it does is flash red/sec when turned on. I have tried charging the batterys, different fully charged batterys, rebinding / calibration, setting the end points on the controller and rebinding. The Esc will not accept calibration when trying to set it up. I have looked online I have gone through the setup in the manual step by step nothing I've done will fix this issue as the ESC will not accept neutral,full throttle, full reverse. On some rare occasion ive have got it passed the red/blinking /beeping by tricking the ESC like turning the controller off and back on when calibrating so I know the calibration was not right but regardless it was passed step stage. It would do its normall start up and arm them immediately flash green light no sound about 15 to 20 times and then flash red/green 3 times and light would go out and you could do nothing except turn it off and repeat the process. At this point I have contacted HH and sent in the ESC and controller. Very frustrating to spend that kind of money and have issuse right from the start. HAS ANYONE ELSE HAD THIS ISSUE?
