I’d say Kraton 6s, great rig out of the box.Hey guys still trying to decide between 8s Kraton or 6s Kraton. Been away from the hobby a while and always wanted a Kraton when they first came out. Thoughts/pros and cons of each. Much appreciated.
I agree with part you need more room to run. Me personally I ran 2 6s cars that were over powered. I also never came away from a day running them that I didn’t break a rear wing mount. To the point I stopped using it. When I went to the 8s after my first run I couldn’t go back and sold both my 6s kratons. The 8s jumps perfectly on its own. I only need to adjust it midair if I came off a jump the wrong way. A year later and I can go 2 or 3 sessions and not break anything on either truck if I’m not going all Tarzan on it!! Most common issue with the 8s is bent axles. But that’s usually from getting some serious air and not landing right. If you go 8s the 2 must have upgrades are aluminum diffs/trans ( I’ve had every mounting bolt eventually just loose the threads). And the power plant. I run max 5 combo In one and a max5 esc and a Tp motor. (50k rpm’s vs 35k on the hobby wing 800kv motor.). Both running 39/39 gears. Both cars hit over 60mph before I run out running room! Tp hits 65 before running out of room and I can tell it’s still got more. Again personally for me I would never go back. I wish I started here instead of the 6s. But. That’s my opinion!6s
LHS talked me out of 1/5 for the above reasons. You need a lot more space to run it and will break more parts secondary to increased mass. 1/5 is so much bigger and needs a larger space for repairs and in the trunk.
I agree...I've shelved my k6 after I got my O8 exb.I agree with part you need more room to run. Me personally I ran 2 6s cars that were over powered. I also never came away from a day running them that I didn’t break a rear wing mount. To the point I stopped using it. When I went to the 8s after my first run I couldn’t go back and sold both my 6s kratons. The 8s jumps perfectly on its own. I only need to adjust it midair if I came off a jump the wrong way. A year later and I can go 2 or 3 sessions and not break anything on either truck if I’m not going all Tarzan on it!! Most common issue with the 8s is bent axles. But that’s usually from getting some serious air and not landing right. If you go 8s the 2 must have upgrades are aluminum diffs/trans ( I’ve had every mounting bolt eventually just loose the threads). And the power plant. I run max 5 combo In one and a max5 esc and a Tp motor. (50k rpm’s vs 35k on the hobby wing 800kv motor.). Both running 39/39 gears. Both cars hit over 60mph before I run out running room! Tp hits 65 before running out of room and I can tell it’s still got more. Again personally for me I would never go back. I wish I started here instead of the 6s. But. That’s my opinion!
