What spur are you running? 47 or 39? I'm guessing stock means the 47?So I have the xlx2 1100kv motor set up with a 31t pinion and stock spur and Im just not seeing the power at And doesn’t wheelie, I’m using cnhl 4S 9500mah batteries, I have the punch setting at max with the castle B link also. Any advise would be helpful. Thanks guys !
Yes I’m running the 47 stock spurWhat spur are you running? 47 or 39? I'm guessing stock means the 47?
Need to switch to the 39 and it'll solve your problem. Like @The_Otherside said, she will be going stupid fastYes I’m running the 47 stock spur
Go higher on ur pinion gear try 34So I have the xlx2 1100kv motor set up with a 31t pinion and stock spur and Im just not seeing the power at And doesn’t wheelie, I’m using cnhl 4S 9500mah batteries, I have the punch setting at max with the castle B link also. Any advise would be helpful. Thanks guys !
The higher you go on the castle punch gives you less punch so if you want to wheelie I would lower the punch so you get more power from the startSo I have the xlx2 1100kv motor set up with a 31t pinion and stock spur and Im just not seeing the power at And doesn’t wheelie, I’m using cnhl 4S 9500mah batteries, I have the punch setting at max with the castle B link also. Any advise would be helpful. Thanks guys !
Good point, a lot of people overlook that.The higher you go on the castle punch gives you less punch so if you want to wheelie I would lower the punch so you get more power from the start
