That sucks. All you need to bring is a set of hex wrenches and you can fix just about anything!So I get some that worked at Home Depot. Went like 5 minutes and this happened. The last 3 times I’ve gone out I’ve gotten five minutes each. Ugh.. I was hoping it would be an on site repair but I couldn’t figure it out.
How bad is this? Thanks
Did you remove the screw holding it in?
It unscrews out of the middle. I didn’t know at first either?
Use a soldering iron or a mini torch to heat it upno I didn’t know that lol. Trying now and I can’t get THAT one loose either!!
So then I decide to try this one and it’s ever so slightly stripped so the 2.5 won’t grab!! Lol
fml
@ts2340 Do it my way, it's a lot faster and can be done in the field with no issues.
https://www.arrmaforum.com/threads/how-to-place-driveshaft-back-into-the-cup.20150/
For your issue:
There is a grub screw inside that holds the pin, probably covered by dirt. Has tons of loctite if this is your first time, heat it up with a torch or soldering iron. Most likely you will strip the screw.
Do it my way and get on with bashing.
Tpo avoid this altogether, remover those spacers and washers on upper and lower arms and this will become less of an issue.
Edit: There is no loctite in that bolt i.e. stripping it takes some poopy tools. Buy yourself a better set and a new pin.
You can either hammer in a torx bit or dremel your way into it i.e. slit and use a screwdriver
